try it set at 0 with volume at 25 using -5db@40hz tone. then you can still turn it up a couple sub level clicks without much worry if a song is quieter like jazz/country. if you use -10db i would not go above sub level 0 to make sure signal stays clean since the gain will be higher using -10db vs -5db
What tone do you suggest to use for people who mostly listen to your tracks?
  • Who's Online   1 Member, 0 Anonymous, 1139 Guests (See full list)
