What makes higher watt amps louder
I know this is probably one of the most rookie questions to ask, but what exactly akes higher rms amps louder. i have been looking for a higher wattage amp than my Kicker ZX300.1 to power my 10" L7's but i kept wondering. If i just turn up the gain on my amp wouldnt that make it louder. Or does that just make it distorted. I am really new to the whole BIG amp scene. i have always had small amps but now i want to find out and see if my amp can be loud by turning up the gain more or if i need a higher rms amp to really make it louder. thanks guys
Car
1999 Dodge Stratus 2.5L V6
Deck
Kenwood DDX-512 Head Unit
Doors
(2) Diamond Audio DA6.6 6.5's
(2) Cerwin Vega 3" Horn Tweeters
(1) Alpine MRP-F240 for Doors & Tweets
Rear Deck(on factory wiring)
(2) JVC 6.5's
(2) Rockford Fosgate 6x9's
Subs firing forward
(2) Skar Audio VVX-12's
(1) MBQuart ONX1500.1D for Subs
Wiring
Cadence 4AWG for MBQuart Amp
Advance Auto 8 AWG for Alpine Amp
Cadence and Monster 4 AWG Wire to Kinetic HC1200
Batteries
Stock Replacement up front
Kinetic HC1200 in the back for the amps.
And yes "I drive a Dodge Stratus"
Here is my build log:
http://www.stevemead...__fromsearch__1
turning the gain up just causes clipping...your better off upgrading to higher powered amp
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Repost sorry
Alpine CDE-hd148bt
Alpine PKG-RSE2
Kicker KX350.4
DC Audio 1.2k
An amplifier is designed to amplify (aptly named) an electrical signal. An audio aplifier takes in a low-current, low-voltage signal and amplifies it into a higher amperage and higher voltage signal using an external power source (wall outlet at home, car batteries). The hardware, design, and circuitry of the amplifier determine how far it can amplify the signal before distorting the signal (adding noise/clipping/etc.) Now a small amp rated at 300 watts uses much less beefy circuitry than one rated at 3000 watts. That is because you need more input amperage from the power source and heavier-duty circuitry in order to amplify a signal that much more.
You can turn your gain knob up to full and you may get more that 300 watts out of your amp but it will be distorted to hell. Buy a larger, proper amp if you need more power. A general rule of thumb is to upgrade your car's electrical system if you plan on going over 1000 watts in order to feed more power to a hungrier amp (bigger alternator and/or more batteries).
It takes power to make power :good:
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
  • Who's Online   0 Members, 0 Anonymous, 1351 Guests (See full list)
