10k+ DDZs No batteries, Big Cap bank, custom built alt, daily driver **153 sealed legal trunk holding 15 volts ish on music**
starting to stain the floor!!
staining day did my home speakers too!!
touched up the box
letting it all dry
looking good
DAT GRAIN
floor stained and done!! clearcoat time!!
handle operation
then i hit it with the clearcoat polyurethene
quick install fit check
ground point to ze frame!! 2 0 guage grounds and stock 4 gauge ground
wire test fit
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
installed with wires
this what handle for
spare access!!!
put velcrow on contact points to hold down and to make sure no rattles
next piece to go on left sidde to support amp rack
came across another problem. my radio wouldn't turn on.
i checked fuse box. fuse on remote ACC turn on circuit was blown. wierd? so i replaced it. the minute i turned key, popped again.
so i had a short comewhere.
i took apart fuse box and tested each wire on the circuit. there was radio turn on and seat heaters on same circuit. lucky for me the left front seat heater wire was the one shorting. i dont have heated seats so i simply clipped the wire tapped it all up and the radio worked again without popping a fuse!!
mercedes dealer wanted 300 just to diagnose the problem. i felt proud i found the wire where it was shorting and i didnt even have to run any new wires or make a new circuit.
BMW M340 xDrive
time to make a battery box/ amp rack for the second D3100 and my SS4a and the m3b amp rack
no contact!!
slightly angled down so amps fit contour of trunk lid
time to stain!!
installing pieces
test fit with blocks made by CARBON!!
shelf test fit!
i put spacers to give amp some airflow underneath
BMW M340 xDrive
more wires to hook batts together
toolmaker dual inputs for the m3b
l brackets to hold box in place
still got 1/8 of an inch
dd sticks
detail on box tie downs
redrilled speaker wire holes through glass
3/8 bolts to hold down box
silicone to make sure they are sealed
BMW M340 xDrive
l brackets bolted down to floor awaiting box!!
and thats all for now!! equipment arriving this week!!!
BMW M340 xDrive
oh wow lol very pic heavy there sir. really clean, the stain loook is pretty sick dude
ive been waiting to get all those up haha.
and yea im loving the stained look. just wait till you see the equipment
BMW M340 xDrive
Holy shit man! Youve been busy workin no doubt!
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
ill be waiting, its a sick build. i think im sealing my trunk off next week but idk lol
what amp you running again
Well I couldn't find another z motor and I'm not gunna be running 1 12. A z really wouldn't have been worth the money when I can't put 10k to it so I traded it for what's coming this week!! Straight up trade and it was best deal ever.
But all I can say is ill be running a foresure 5k at 12 volts and once I get my alt in hoping to get 7-8k out of the amps
And yes if course it will be all dd
BMW M340 xDrive
