10k+ DDZs No batteries, Big Cap bank, custom built alt, daily driver **153 sealed legal trunk holding 15 volts ish on music**
Ok you have my attention! That might be the most outrageous thing I've ever seen in car audio. I didn't listen to it so let me make sure I got this straight, 10k to one 12" woofer dropping .1v briefly?!
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
It prolly isn't 10k. But it is as loud or louder than my 2 z95 12s. But voltage drop is right.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
BMW M340 xDrive
yep i'm getting caps. screw batts and their weight.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
These are the prelim drawings of the cap bank straps and bus bars.
here is the highs amp rack. youll notice i had both amps on the front but after seing how box would fit, the JL moved to the rear of this amp rack and the DD SS4a stayed on the front.
clear coat
borrowed da truck to get some wood
BMW M340 xDrive
dat grain!! dat 13 ply euro birch!!
cutting out the floor!! contoured
pieces cut tongue and groove
double layered box yes.
test fit
face of da box
kinda test fit
BMW M340 xDrive
so how we gunna get some power in here.
i decided to build my own alt. here is the first ever version of my 270 A alt,
its a large case gm. I planned it to do 160 hot at idle. 200 cold at idle. and around 290 cold peak and 240 hot continous under 1800 rpm
dat square stator doe
my custom rectifier for up to 3 output posts. and also using 70A diodes (all other companies are using 50A diodes.)
good contact points
open er up
here is the second go at it
I call her the hulk
BMW M340 xDrive
even matched stator tips with green
super solder
loaded up with an internal regulator
2 output posts for those running lots of wire like me
clutch pulley anyone?
sexy
BMW M340 xDrive
remember those drawings from earlier, well i went through a cad program and got them perfect, sent the designs over to toolmaker and he made these to spec.
i designed to be able to handle 1600A+ continous and over 32000A peak for short bursts. needless to say, they are plenty.
GOT CAPZ
got toolmaker?
starting to build banks
complete bank
charging up with water cooled resistors
dat stock connection doe
fuse block for runs to alt
this what happens when some sort of reaction takes place on the positive side of the resistors combined with too much current
BMW M340 xDrive
here is a little preview of something im workign on ;)
BMW M340 xDrive
