Mad_Mike Posted January 14, 2012 Report Posted January 14, 2012 I'm going to be running two AQ HDC318 dual 2's on an AQ2200D.1 at .5 ohm. They recommend 200A external fuse so I figure a DC 270xp alt should do just fine to power this. I'm also going to replace my battery with an XS power D3400(biggest that will fit). So wiring wise, here's my list. Please help me out if I'm missing anything I'll need.. 50' Roll of XS Power XP Flex 1/0 - For big three, and to run to the amp. 10 Red, 10 Black XS Power 0AWG terminal ends - It's actually cheaper to buy 20 than it is to buy only 10 15' rockford fosgate 12 gauge speaker wire 4 12 gauge terminal ends - Going to be bolts in the box for speaker wires 2x RFFANL ANL fuse holders, RFFA200 200 amp fuse, RFFA300 300 amp fuse from Rockford - 1 for bat to alt, and 1 for amp run RFIT16 16 feet of rockford twisted signal cable - It's a truck 17' of turn on wire from rockford - got it laying around
MIKE-2U Posted January 17, 2012 Report Posted January 17, 2012 Looks like you have it all.all the wiring for big 3 all wires for subs and amp. Should be set. Lemme how it goes i also just got a 2200D running at 1 ohm though. 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
