2amp on dual-2 OR 1amp on dual 1?
what amps? if the 2 amps are putting out as much as the single amp there shouldnt be a diffrence
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
If you are looking at two 1,000 watt amps...then you are looking at 2,000 altogether. Two subs to the same amp would be 1,000 watts, 500 watts a piece. Not equal power at all.
I bought 1 SSD 15 with dual-1ohm. I wish now I had bought the dual-2.
I'm wondering if I get a second, and wire them to 1ohm if I would get more spl out of my amp. I'm 2ohm right now (dual-1 in series), if I got a second I can get 1ohm, and I'm THINKING it would be noticeably louder.
just run yer sub at 2 ohm on that amp..ssd is only 800 rms im sure that mbquart does close to rated..
1999 grand prix gt
Even if wired to 1ohm? Does 2 loads (subs) cut the power (watts) in half? Even still would I get more spl if I went with 2 Dual-1 wired to 1ohm? Right now I'm getting 750watts, if I'm correct I'll either get 2 subs doing 750watts instead of one.
However, if my original thought was correct, I would get 2subs doing 1500watts. <--- That is likely wishful thinking.
SSD is beast and like many great FI/AA products...grossly underrated.
If you truly want something beast, I would sell the amp for a larger amp and then run two D1s to a 1 ohm nominal to the amp.
  • Who's Online   1 Member, 0 Anonymous, 341 Guests (See full list)
