8MileRoad Posted January 16, 2012 Report Posted January 16, 2012 How would i wire one dual 2 ohm voice coil subwoofer to a 2 channel amplifier at 1ohm and at 0.7 ohms Thanks In advance
BassJunkie Posted January 16, 2012 Report Posted January 16, 2012 You're only going to be able to wire down to 1 ohm depending on what speaker it is. You may see .7 ohms if your running Fi but you wont see .7 if you're running kicker. Be sure that your amplifier is 1 ohm stable, I don't remember seeing alot of 2 channel amps being 1 ohm stable. 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router.
8MileRoad Posted January 16, 2012 Author Report Posted January 16, 2012 You're only going to be able to wire down to 1 ohm depending on what speaker it is. You may see .7 ohms if your running Fi but you wont see .7 if you're running kicker. Be sure that your amplifier is 1 ohm stable, I don't remember seeing alot of 2 channel amps being 1 ohm stable. its an 18, thanks for the diagram
STEvil Posted January 17, 2012 Report Posted January 17, 2012 That will be 0.5 ohms on a 2 channel amplifier. Those wiring diagrams are for monoblock (single channel) amplifiers. When you use two channels or strapped amplifiers your impedance is halved across each channel/amp. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
