double
Edited by KHRISS
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
you CANT mix them up thats way they come in a complete set you should get your money back
Edited by KHRISS
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
no x overs just tweeter and driver. What should i use to fill gap of xover?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
You'll ned some sort of x-over whether it be active or passive. Active can be at an ampp or you can contact rainbow directly and see if they recommend a passive setup. Typically you want to cross over an octave below the drivers drop off. whether it is the drivers Fs or the midranges drop off at higher freq. Give us the model no. of the speakers and we can help you sort it out.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
Rainbow SLX -Line W-165 EURO
You have options....you could buy some passive xovers like the one pictured above. Check eBay for an MR series xover by Aura, its a decent unit thats very affordable. You could run the mids high passed at like 80hz off ur amp and run some bass blockers on ur tweets. You could also run an electric xover and dial it in to what sounds good to you. The first one is probably gonna be the easiest but if the xover points arent high enough it wont sound good. The second is gonna be the most affordable but bass blockers are kind of a low budget way to do it. The electronic xover would probably be the best way to do it but also the most expensive.
Edited by SQMonte
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
Is this what you have looks like. The 265 is a component set that uses the same midbass driver. I would check to see if the tweet matches up to the one in that comp set and if it does you can buy a pair of the passive x-overs that go with the set and you'll be golden.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
That is the newer version of the one's he has
So if i buy those xovers and have the amp wires go to this then too the tweeter and mid that is active?
and can i just use a 3 channel amp , one for each side ? and what do my settings on the amp havre to be ? i would assume nothing except gain because the xover is filtering all of it , right?
