Finally designed a box, but can't calculate it right
I'm using Torres calculator, but some of the terminology is confusing me and when I add any braces the calculator stops showing the tuning. Can someone please help me figure out what this box is? Every dimension that should matter I 'should' have included, if you need one please let me know! Also, I will be adding anther sheet of wood to the top, if I understand correctly that shouldn't change anything.
These next two pics have the bracing in it. It's 2"-Wide, .75"-Long, and 19.75"-Tall
Thank for your help. I'll post what my Torres after a few replies.
Thanks!
I found one I forgot to include From the very bottom to the very top of the box is 24.75".
24.75" DOES include the 2 "baffles?". aka pieces of wood that have holes for the subs.
bump anyone who knows how to use Torres care to punch in numbers? I would appreciate it very much!
Last bump then I'll let it die. Below is my Torres, but I don't think it's right. Also, when I add the brace in it stop giving me a tuning. Thanks for any and all help!
From start, that tuning is hella low bro lol.
What subs these for?
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Daily driving. Also, I'm not sure that Torres pic is right. I had someone build me a box, and his Torres screen shot was MUCH fuller. I just don't know what most of that is. That said, I was hoping someone would plug in the correct number for me.
i think he meant what brand of subs since your tuning in the 26hz range
Fi SSD 15"
Also, I think everyone is forgetting, I do NOT think I am doing the Torres Calculator correctly. I posted mine only so someone could figure out what I'm doing wrong.
I would like for someone to do the Torres Calculator for me. There is terminology that I don't know or use. "# of common port walls", "length of external ports". I don't understand some of this, and would great appreciate someone doing the calculations for me.
  • Who's Online   0 Members, 0 Anonymous, 1201 Guests (See full list)
