Hadec Posted January 20, 2012 Report Posted January 20, 2012 I got my system hooked up by "professionals" and here is their work. Pics of amp setup... Working on my first car audio build ever! Currently have: - 1996 Lexus LS400 sedan - Diablo Hellfire Proto Amplifier - (2) 12" Fi Bl Subwoofers - Vented subwoofer enclosure from Perfect Soundz - Installed by Perfect Soundz Needs: - Battery: probably XS Power 12V 2400 - "The Big 3"
MIKE-2U Posted January 20, 2012 Report Posted January 20, 2012 When it does that how long till it stays off ? feel if its hot next time. Is there any certain thing that when you do it , the amp turns off ? A low note? check to see if the red light is one. Professionals i would "HOPE" they know what they are doing. The dimming of the lights probaly isn't effecting it to turn off. 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
Hadec Posted January 20, 2012 Author Report Posted January 20, 2012 Then the amp must be overheating when the gains are set in the middle.. They are not even all the way up. Or does the -2 degree weather effect it? I made sure to warm up my car for 10 minutes. I do not have a head unit either. I am using my stock Lexus head unit and a tape/cassette to ipod jack for my iphone. My iphone has the EQ settings turned off. By the way I can't even turn off my bass since I'm using my stock head unit. I can just turn it all the way down and it still bangs. When the bass first completely turned off I immediately turned my volume all the way down. Then I would try to turn it up like a minute later while driving and it would hit one bass note then shut off again. Working on my first car audio build ever! Currently have: - 1996 Lexus LS400 sedan - Diablo Hellfire Proto Amplifier - (2) 12" Fi Bl Subwoofers - Vented subwoofer enclosure from Perfect Soundz - Installed by Perfect Soundz Needs: - Battery: probably XS Power 12V 2400 - "The Big 3"
kraz1021 Posted January 20, 2012 Report Posted January 20, 2012 some questions 1st how did they wire 2 dual 1 subs to a final impedence of 2ohms.if you have dual 1 subs they should of wired it to 1ohm or 4ohms 2nd whats your electrical consit of,i know u have a stck batt(which should be upgraded running that much power) but have you done the big 3,do you have a HO alt. by professionals im taking it that a local shop did your install.if they told you they hooked up 2 dual 1ohm subs to a final 2ohm load then they must not know what their doing or talking about IMO
Hadec Posted January 20, 2012 Author Report Posted January 20, 2012 website lagged and created lots of the same posts. Working on my first car audio build ever! Currently have: - 1996 Lexus LS400 sedan - Diablo Hellfire Proto Amplifier - (2) 12" Fi Bl Subwoofers - Vented subwoofer enclosure from Perfect Soundz - Installed by Perfect Soundz Needs: - Battery: probably XS Power 12V 2400 - "The Big 3"
Hadec Posted January 20, 2012 Author Report Posted January 20, 2012 website lagged and created lots of the posts. Working on my first car audio build ever! Currently have: - 1996 Lexus LS400 sedan - Diablo Hellfire Proto Amplifier - (2) 12" Fi Bl Subwoofers - Vented subwoofer enclosure from Perfect Soundz - Installed by Perfect Soundz Needs: - Battery: probably XS Power 12V 2400 - "The Big 3"
