TeenBassHead Posted January 21, 2012 Report Posted January 21, 2012 Okay so I'm putting a D2 SA-12 in my 2001 Chevy S10 ext-cab. The Sundown site says the sa-12 needs 1.75 cubes at ~30hz. I came up with this in Torres, how does this look for a box? Sub will be facing up, port firing towards the passenger. Box will be behind the driver side seat. Thanks, give me some tips.
Socky Posted January 21, 2012 Report Posted January 21, 2012 Are you using aero's or pvc for the port, if it was me i would do 2 4" aeros with the sub forward and port up, loudest in the s10's. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
TeenBassHead Posted January 21, 2012 Author Report Posted January 21, 2012 whats the difference between PVC and aero? and if i used 2 4" aeros, the tuning would be too high, cause i gotta keep the length of it under 25. and the only way the tune can stay at below 34hz is if its at like 30 something length.
TeenBassHead Posted January 21, 2012 Author Report Posted January 21, 2012 i re-did it, using 2 3" aeros. the height is 20", width is 13.5" and length is 18". the tune comes out to 32hz and the volume comes out to ~1.96 cubes
