this is what we did to xterraboy03's truck and it works great. xs and mechman said stock electrical should take it no problem and it did
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Check with dd on the m4s maximum operating voltage before you do 16v..I know m series are sesigned for 12v... when I ran 14 to15v they ran warm at 13 14v they were cold ....plus new m4as protect at 15.3 I never got m4 to protect from voltage but high voltage is bad for electronics for daily..it turns to heat sir
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
he has 2 xs power d1400's
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
Well its your old amp ray so what is the highest I can get away with? I really wanna hit 5000 rated so i can run 2 DC LVL 5M2.
But thanks for the help guys now I kind of have an idea of what needs to be done.
03 Wrangler Sahara
6" lift (5 inch suspension 1 inch body)
20" Boss Rims with 33" tires
Front and back bumper guards
4 3/4 ton winch
Kenne Bell supercharger with cold air
Full Exhaust
Pioneer mvh-p8200bt
Pioneer Components
COMING SOON...
3 12" Kicker CVT's
RF T1000.1BD
if you run 16+ volts charging I recommend step down module(s) and a 12v batt up front to keep your vehicle electrical safe.
"should be safe" is very different than IS safe in my opinion.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Id run it 12v with the electrical to support 500 amps... at least a 270amp alt and 3 or more 3100s.... charge them at 15v..and wire the amp to .7...an there aren't any m2s lvl5s yet.. id do m2xls or m2lvl4s
Edited by dc98hoe
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
