box calc help
lotus
my box is 15high x 32.5wide x 25deep. the port is 13.5high x 4.5wide (19-22deep depending on what will get me 355hz) i have 2 XD 12s. .28 displacement with 3 common walls since its an L shaped box. i am double baffling the front of the box where the subs go in. so it will be 25.75deep. i am putting 2 45s in 2 corners and 2 dowels that are 1in in diameter and 15 13.5high. what should the tuning length be? i want 35hz and i only have 13.8 port area per foot if thats enough
2010 Cobalt LT Coupe
Subs: 2 American bass XFL 12s
Amp: Crescendo BC3500D
Big 3 in 1/0awg
29hz box
stinger volt meter
2nd battery Deka 9a31
pioneer DEH-9400BH
If the box is not already physically built then
this seems to be around what you want and about right for generic 12"s depending on the power run to them and the drivers themselves Vb should be set higher or lower, it features a double layer baffle:
Enclosure Specifications:
Fb = 35,015 Hz
Vb = 3,962 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 15 in
External Width = 32,5 in
External Depth = 24 in
Port Width = 4 1/2 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 27 1/4 x 13 1/2
Front Internal = 26 1/2 x 13 1/2
Back = 32 1/2 x 13 1/2
Left & Right Sides:
Side 1 = 22 1/2 x 13 1/2
Side 2 = 21 3/4 x 13 1/2
Top & Bottom = 32 1/2 x 24
L Port Internal Assembly Parts:
Front to Back = 18 x 13 1/2
Extension = 1 x 13 1/2
Generic dims assembly guide:
you think this box would be a good for 2 american bass XFL 12s?
Big 3 in 1/0awg
29hz box
stinger volt meter
pioneer DEH-9400BH
Yes, they are recommended for vented enclosures 1.5 to 2.5 cubic feet per sub so 2 cubes per sub is right in the middle.
Take a look:
http://www.google.com/url?sa=t&rct=j&q=american_bass_xfl1244_11.10_v3_final.pdf&source=web&cd=1&sqi=2&ved=0CCAQFjAA&url=http%3A%2F%2Fwww.americanbassusa.com%2Ffiles%2Fpdf%2FAmerican_Bass_XFL1244_11.10_v3_final.pdf&ei=j5ohT_KOG8LksQKlqey8CQ&usg=AFQjCNEdrEQD3rW5w8Oz7H2TyQVtFrrB_g&cad=rja
Take a look:
thnx
Big 3 in 1/0awg
29hz box
stinger volt meter
pioneer DEH-9400BH
  • Who's Online   0 Members, 0 Anonymous, 917 Guests (See full list)
