2 12" DC lvl 3 Enclosure Design
Mile High Guy
Ok so due to port turning I failed to add the increased centerline length in the turn:
Centerline Port Length:
9 + 0.75 + 1.375 + 16.3125 = 26,6875
Effective Port Length:
PL = 26,6875 + 0.5x1.375 = 27,375
So really specs as follows:
Fb= 34.19Hz
Vb = 1.439 cuft (per chamber)
BUT since friction in the side ducts is different than in the center duct since is wider, I don't think the standard tuning equation the Torres uses can predict the real tuning as this equation works only on constant cross sectional area ports.
Not sure if it will be off by far or it will be inaudible though.
so if the width of the port is the same throughout the entire port, then the standard tuning equation that torres box calculator uses would be accurate?
Headunit - Alpine 9857
Mids & Highs - T165,T1692
Mids & Highs Amp - T400-4
Subs - 2 12" DC Audio Level 3 M2s
Sub Amp - T1500-1bdcp
Alternator - MechMan 220a
Wiring - 1/0ga XS Power
Batteries - 2 Optima Yellow Tops
Read the fucking manual. Jesus Christ.
I dunno about that Steve...
Chuck Norris doesnt even do push-ups, he just pushes the earth down.
If you are interested in this I recommend reading the following document, is the same document Torres used for his program:
http://www.jlaudio.com/header/Support/Tutorials/Enclosure+Ports/Tutorial%3A+Enclosure+Ports/656168
Towards the end it explains the fallacy in port area considerations when using multiple ports. The same applies to the T port.
ok cool i'll read it. thx for the link.
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
