Ok when doing the big 3 do you have to fuse the ground wires? and is there any time you would want to fuse a ground (like if you were running it from the front to the back)?
No and no. No need to run grounds from front to back.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
i mean like if you were doing a run from your batter - to the ground on your amp you woulnt have to fuse it?
No and it would be better to run a ground from your amp to the frame in the back.
B5 Passat Build Log
  • Who's Online   0 Members, 0 Anonymous, 1433 Guests (See full list)
