down2earth Posted April 25, 2012 Author Report Posted April 25, 2012 yeah guys not much going on still waiting for a welder to get here but i order a Porterbuilt Dropmember it will be here in 3 weeks then im going to order my a-arms from michigan metal works Description: The Porterbuilt Dropmember is a bolt-in front suspension system designed to eliminate all the drawbacks traditionally associated with extreme lowering of the 60-87 Chevrolet trucks. It is available for the C10, C20, and C30 chassis. Its improved/revised suspension geometry and rack and pinion steering improve both ride quality and performance. It raises the suspension components in the chassis to eliminate ground clearance concerns, making the frame-rails under the cab the lowest point; narrows the trac-width by approximately 1 1/2 inches, per side, for increased tire clearance; and moves the wheel center-line forward, centering the wheels in the wheel well opening and eliminating tire to firewall clearance normally asociated with laying frame and large diameter wheels/tires. The Dropmember is compatible with factory upper control arms from 1963-1987 and factory C10 lowers from 73-87. Basic Kit Includes the following ($1099): -Main crossmember assembly -Inner truss support system -Motor mounts (SBC, BBC, GEN3, and I6 available) -Upper shock relocator brackets -Transmission crossmember -Rack notches -Tie rod assemblies -Billet mounting bushings for rack and pinion -Grade 8 hardware for installation my 1949 ford f-1 build log http://www.stevemead...running-boards/ my 1981 crew cab dually bagging and body dropping http://www.stevemeadedesigns.com/board/topic/132672-bagging-and-body-dropping-a-81-crew-cab-dually/page__st__100
bmfcustoms Posted April 29, 2012 Report Posted April 29, 2012 Mines a 79 shortbed. Big ole 250ci 6'er. Ive got the porterbuilt dropmember on mine. I love it. And their customer service is 2nd to none.
down2earth Posted May 1, 2012 Author Report Posted May 1, 2012 Mines a 79 shortbed. Big ole 250ci 6'er. Ive got the porterbuilt dropmember on mine. I love it. And their customer service is 2nd to none. truck looks sick man cant wait till mine is done my 1949 ford f-1 build log http://www.stevemead...running-boards/ my 1981 crew cab dually bagging and body dropping http://www.stevemeadedesigns.com/board/topic/132672-bagging-and-body-dropping-a-81-crew-cab-dually/page__st__100
down2earth Posted May 6, 2012 Author Report Posted May 6, 2012 i just order my a-arms yesterday from Michigan Metal Works $1000 dollars but they are well worth it my 1949 ford f-1 build log http://www.stevemead...running-boards/ my 1981 crew cab dually bagging and body dropping http://www.stevemeadedesigns.com/board/topic/132672-bagging-and-body-dropping-a-81-crew-cab-dually/page__st__100
sik99ranger Posted May 7, 2012 Report Posted May 7, 2012 thoes arms are hott!!!! the flat iorn is sick!!
down2earth Posted May 12, 2012 Author Report Posted May 12, 2012 i got the new welder east wood mig 175 was $499 today and to get the bottle filed was $118 so im rdy to get started back up tomorrow and get this frame done my 1949 ford f-1 build log http://www.stevemead...running-boards/ my 1981 crew cab dually bagging and body dropping http://www.stevemeadedesigns.com/board/topic/132672-bagging-and-body-dropping-a-81-crew-cab-dually/page__st__100
sprkn_ranger Posted May 12, 2012 Report Posted May 12, 2012 Eastwood? Never heard of that brand before...are they a newer company? Those arms are badass man! Looking forward to more updates Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
down2earth Posted May 12, 2012 Author Report Posted May 12, 2012 Eastwood? Never heard of that brand before...are they a newer company? Those arms are badass man! Looking forward to more updates they have been around for a good bit of time there are lots of good reviews on it but ill see how it welds tomorrow and it come with a aluminum spool gun my 1949 ford f-1 build log http://www.stevemead...running-boards/ my 1981 crew cab dually bagging and body dropping http://www.stevemeadedesigns.com/board/topic/132672-bagging-and-body-dropping-a-81-crew-cab-dually/page__st__100
down2earth Posted May 14, 2012 Author Report Posted May 14, 2012 im back up and running started to plate the z in got 1 side all most done then i just need to put the 1/4 in plate on the out side and in side then 1 side will be done here is a pic the new welder is fucking nice my 1949 ford f-1 build log http://www.stevemead...running-boards/ my 1981 crew cab dually bagging and body dropping http://www.stevemeadedesigns.com/board/topic/132672-bagging-and-body-dropping-a-81-crew-cab-dually/page__st__100
