WadeTustian Posted January 29, 2012 Report Posted January 29, 2012 ok so i got the box built up today and wired it all up, i was expecting alot louder and boomier bass, but it is not louder. im fairly disapointed, any suggestions or should i just sell the box? its a 12" kicker L5 and a Mb Quart 600.1 wired to 2 ohms 2007 Mazda 3 Sedan Pioneer 80-prsB2 Zero.7 2 15s 4inch coil psi recones temp til my subs are reconedFocal P165-v15Audison voce quattro fully activeOnly gonna get louder 146.1 at 38hz 138.x at 24hzBuild log http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
Rd Alpha Max Posted January 29, 2012 Report Posted January 29, 2012 what are the box specs? Is it ported? System 1997 Saturn SC1 Trunk Wall 2 Obsidian d2 12s 4.1cu. @ 30hz SAZ 1500d @ 2 ohm 1/0 Welding Cable Stock alt Big 3 in 1/0 Welding Cable
WadeTustian Posted January 29, 2012 Author Report Posted January 29, 2012 what are the box specs? Is it ported? its this design here http://imageshack.us/photo/my-images/23/235cubes33hz325sqin3id.png/ only diffrence is i made it 16 inches tall rather then 14.5 2007 Mazda 3 Sedan Pioneer 80-prsB2 Zero.7 2 15s 4inch coil psi recones temp til my subs are reconedFocal P165-v15Audison voce quattro fully activeOnly gonna get louder 146.1 at 38hz 138.x at 24hzBuild log http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
Rd Alpha Max Posted January 29, 2012 Report Posted January 29, 2012 put some 45's in the port corners System 1997 Saturn SC1 Trunk Wall 2 Obsidian d2 12s 4.1cu. @ 30hz SAZ 1500d @ 2 ohm 1/0 Welding Cable Stock alt Big 3 in 1/0 Welding Cable
WadeTustian Posted January 29, 2012 Author Report Posted January 29, 2012 put some 45's in the port corners will this make a big diffrence??? 2007 Mazda 3 Sedan Pioneer 80-prsB2 Zero.7 2 15s 4inch coil psi recones temp til my subs are reconedFocal P165-v15Audison voce quattro fully activeOnly gonna get louder 146.1 at 38hz 138.x at 24hzBuild log http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
Rd Alpha Max Posted January 29, 2012 Report Posted January 29, 2012 it helps the air flow in the port so it doesn't just hit a wall. Just try it and see if it helps. System 1997 Saturn SC1 Trunk Wall 2 Obsidian d2 12s 4.1cu. @ 30hz SAZ 1500d @ 2 ohm 1/0 Welding Cable Stock alt Big 3 in 1/0 Welding Cable
WadeTustian Posted January 29, 2012 Author Report Posted January 29, 2012 it helps the air flow in the port so it doesn't just hit a wall. Just try it and see if it helps. Ok, how big should I make the 45 to put in the corner of the port? I'm a Noob 2007 Mazda 3 Sedan Pioneer 80-prsB2 Zero.7 2 15s 4inch coil psi recones temp til my subs are reconedFocal P165-v15Audison voce quattro fully activeOnly gonna get louder 146.1 at 38hz 138.x at 24hzBuild log http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
WadeTustian Posted January 29, 2012 Author Report Posted January 29, 2012 Any other suggestions to make it the louder boom we where expecting? 2007 Mazda 3 Sedan Pioneer 80-prsB2 Zero.7 2 15s 4inch coil psi recones temp til my subs are reconedFocal P165-v15Audison voce quattro fully activeOnly gonna get louder 146.1 at 38hz 138.x at 24hzBuild log http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
