cichlidfort Posted January 22, 2008 Report Share Posted January 22, 2008 correct Well won't the ring terminals used for the big three interfere with the ring terminal that is sending power to my amplifer? Because the ring terminals for the big III and the ring terminal for my amp would be touching. Is that a problem? 2008 Chevy Impala (undercover cop style) Setup in the makings Link to comment Share on other sites More sharing options...
ChevyBoy Posted January 22, 2008 Report Share Posted January 22, 2008 your battery connects them together anyway......right? Link to comment Share on other sites More sharing options...
ChevyBoy Posted January 22, 2008 Report Share Posted January 22, 2008 just put your ring terminals onto your battery. thats fine if all positives touch. thats fine is all your negatives touch. just as long as your negatives dont touch your positives. Link to comment Share on other sites More sharing options...
cichlidfort Posted January 22, 2008 Report Share Posted January 22, 2008 your battery connects them together anyway......right? Well I would hope so..lol. But I am saying, since the ring terminals would be touching, it would't be a problem if the ring terminals were touching? 2008 Chevy Impala (undercover cop style) Setup in the makings Link to comment Share on other sites More sharing options...
ChevyBoy Posted January 22, 2008 Report Share Posted January 22, 2008 no there wont be a problem. Link to comment Share on other sites More sharing options...
cichlidfort Posted January 22, 2008 Report Share Posted January 22, 2008 I am going to be having a 160 amp alternator. Can I use 4 gauge wiring even though I am using 0 gauge wiring for my system? If I am using 4 gauge does this mean I have to use something such as a 300 amp fuse? Can I just use like a 200 amp fuse? So for one of the negative runs, I am having a wire go from the engine block to the frame...question is, what the hell is an engine block? lol. Sorry for the noob questions, I just want to get this exactly right so I don't mess up. 2008 Chevy Impala (undercover cop style) Setup in the makings Link to comment Share on other sites More sharing options...
EricM9104 Posted January 22, 2008 Report Share Posted January 22, 2008 No. Use 1/0ga wire from the alt to the battery. 4ga is only good for about 140a, anything higher, insulation melts, possible fire if there's no fusing on it. 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
ChevyBoy Posted January 22, 2008 Report Share Posted January 22, 2008 your engine block is your engine for wiring, do the big 3 in whatever size wire you have running to your amp/amps. if your case 1/0. and for fusing, use a fuse a little bigger than what your alternator can put out. Link to comment Share on other sites More sharing options...
cichlidfort Posted January 22, 2008 Report Share Posted January 22, 2008 No. Use 1/0ga wire from the alt to the battery. 4ga is only good for about 140a, anything higher, insulation melts, possible fire if there's no fusing on it. Yeah I just went back and figured it out. So when I get my new alternator in I am going to order knukonceptz flex 1/0 gauge wire, about 10 ft. of it. Then I am going to order six 0 gauge ring terminals, a fuse holder and and a 200 amp fuse. 2008 Chevy Impala (undercover cop style) Setup in the makings Link to comment Share on other sites More sharing options...
cichlidfort Posted January 22, 2008 Report Share Posted January 22, 2008 your engine block is your engine for wiring, do the big 3 in whatever size wire you have running to your amp/amps. if your case 1/0. and for fusing, use a fuse a little bigger than what your alternator can put out. So I am attaching a ring terminal to any part of the engine that's metal? 2008 Chevy Impala (undercover cop style) Setup in the makings Link to comment Share on other sites More sharing options...
