ok first off i have a 320 amp dc engineering alternator never tested still brand new and i wanna run 2 12 inch stroker pro they are dual 2 ohm dvc 2500 wrms so im left with .5 ohm. seeing the alternator that i have what would it take to run these stroker pros without burning the amp its either 2 ohm for now until i buy another aq or try and run .5 ohm for now what u guy's have to say about that,2 runs of o gage and 2 100 ah sparta batteries plus i have 2 optima a red top under the hood and a yellow top in the back or and the alternator charges at 14.8 volts will this be too high for 12v batteries and my electrical system????????
Edited by buju2003tt
Aq will be fine at .5.. watch voltage drop.put a stinger meter right on amp inputs........
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
how low is to low with the aq at0.5 ohms and my other question? Is that 320 amp alternator too much for 4 batteries,I have 2 optima a red and a yellow top and 2 sparta 100 ah batteries
  • Who's Online   1 Member, 0 Anonymous, 569 Guests (See full list)
