Directed D1200 amp now need speakers HELP!!!
elflako17
Hey guys my dad just got me this amp in which is a decent amp for 100 dollars I was impress now here are the specs
Directed D1200 amp
Class-D Monoblock Amplifier
Super-efficient Class D PWM design runs much cooler than conventional amps
RMS Power Output:
300 watts x 1 chan. @ 4 ohms
400 watts x 1 chan. @ 2 ohms
600 watts x 1 chan. @ 1 ohm
High-speed MOSFET switching power supply
High-current complimentary Class D MOSFET outputs stable into one ohm loads
Thermal, DC offset, reverse polarity, and short circuit protection with status LED
Continuously variable 12dB/Oct low-pass crossover
Switchable 24dB/Oct. subsonic filter
Switchable 8dB bass EQ
Switchable 180° phase inversion
Remote subwoofer level control
Master/Slave Function
Variable input sensitivity: 150mV - 7.5V
Chrome-plated wire terminals and RCA connectors ensure maximum signal transfer
Rugged 2-piece heatsink and cover
RCA Outputs: 1 pair
LED/FAN Connector: provides power for optional LED light or cooling fan
1-year SonicElectronix.com warranty
Now he got me 2 kenwood 12" subwoofer with single 4-ohm voice coil
Stainless steel-coated polypropylene cone with rubber surround
1200 Watts Peak power handling
400 watts RMS power handling
Frequency response: 25-800 Hz
Sensitivity: 90 dB
Mounting depth: 6-11/16"
Sealed box volume: 1.25 cu. ft.
Ported box volume: 1.5 cu. ft.
Now as you can see the amp is to much for the speakers would the amp be good for SKAR Audio VVX-12" Sub Woofer 4-ohm?
Edited by elflako17
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
and please help me with the hole ohm situation right now the speakers are connected dei-d120045.jpg the 2 subwoffers are connected in the 4 inputs and am not really getting any base because am not getting all the power
2010 Mazda 3
*Rebuild Time*
Make sure your wired to 2 ohms but even at 2 ohms your only getting half the power.
subwoofers - two eclipse 88120s
box - 3.4 cubes tuned to 32 hz
amps - aq1200 and pheonix gold zx450
New build :
2 obsidian audio 15s
same amp
6.1 cubic foot box tuned to 32 hz in a civic hatch
