If the amp is a 2 channel amp what you drew will blow up your amp for 2 reasons: Firstly its a 0.5 ohm load, secondly you mixed your channels.
You need to keep the channels separated unless you are bridging, and in that case only a single negative and a single positive connection are used. If you bridge a 2 channel amplifier you need to halve the final calculated impedance. That means at a 0.5 ohm load the amplifier will see 0.25 ohms on each channel.
Technically speaking, it is still .5 ohms, bridging an amp does not reduce ohms. Bridging an amp increases minimum ohm capability however.
Please read slowly what I wrote.
Hammerdown... 1%
