:No: pic Edited by Chrylser200s
2011 Chrysler 200 S (Black on Black on Black w/ black trim) :)
Changing all the time but, for now.....
*Coming Soon*
80sq ft. SS Damp Pro (INSTALLED)
36sq ft. SS Luxury Liner (INSTALLED)
Big 3 (RF 0 Gauge)
All RF power wire, speaker wire, RCA's
RF T3 6.5" components (2 sets) have
RF T800-4 ad (mids & highs)
XS Power D925
XS Power D3400 have
still undecided on sub/sub amp
Looks like .5
That's not right cuz in the pic he drew he's using both channels. Im not sure the ohms on this one
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
You want this right?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
If the amp is a 2 channel amp what you drew will blow up your amp for 2 reasons: Firstly its a 0.5 ohm load, secondly you mixed your channels.
You need to keep the channels separated unless you are bridging, and in that case only a single negative and a single positive connection are used. If you bridge a 2 channel amplifier you need to halve the final calculated impedance. That means at a 0.5 ohm load the amplifier will see 0.25 ohms on each channel.
Hammerdown... 1%
Technically speaking, it is still .5 ohms, bridging an amp does not reduce ohms. Bridging an amp increases minimum ohm capability however.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
  • Who's Online   0 Members, 0 Anonymous, 1033 Guests (See full list)
