Bonkers51 Posted February 9, 2012 Report Posted February 9, 2012 How do you start a new forum? I'm new to this
8UWITH6 Posted February 10, 2012 Author Report Posted February 10, 2012 The box is way big for 2 HX2 10" be aware that the follwing suggestion is not a proper design has excessive port area, this was done to take up the also excessive net internal volume which should be 2 cubic feet according to RF for 2 HX2 10" drivers: Enclosure Specifications: Fb = 35.2 Hz Vb = 2.321 ft^3 Subwoofer Mounting = Front Mounted Internal Height = 11 in Internal Width = 31.5 in Internal Depth = 18.25 in Port Width = 4 1/4 in L Port Internal Assembly Parts: Front to Back = 14 x 11 Extension = 16 1/4 x 11 Let me know any questions. Joe I wanted to say thank you for your replies. I am fairly new to vented enclosures. I have been running sealed for many many many years. I enjoyed the flat response and ease of installation. Then I heard a nice vented enclosure with a decent amount of power and it was all over from there. Point is I understand that the subs need a net volume after port displacement. I understand the port needs to be a certain width and length for tuning purposes. This enclosure pictured above I think had about 4 to 6 inches cut off the back of it. It was otherwise I think a decent build enclosure with 3/4" and 1" MDF for the T1's that where in it. I just dont understand the size of the port in this case. It seems very large. Would it be better to make a new faceplate on the enclosure and basically start over? Otherwise, is this something I can redo the port for even a higher frequency around 38 to 40hz and still be able to use it as a nice backup box or garage box? Thanks for the input fellas. 1986 Buick Regal Grand National(1) RFD2210 1.25 CUFT @ 38hz Slot PortRFX-9420, Punch 4080dsm, Power 250m22003 Mercury Marauder - Dark Blue PearlDDX-419, T600-4, T2652-S, HPC2205 (Currently Working on Designing an Enclosure)
Joe X Posted February 10, 2012 Report Posted February 10, 2012 It's not good practice to patch up like it's being done here, it would work anyways - suboptimally, it's just that it's ridiculosly big and heavy box to carry a couple of 10", if you ask me, sure, I think that it would be more work to modify that than start over.. it's your choice.
Dappa5 Posted February 10, 2012 Report Posted February 10, 2012 just start over ..trying to fix not worth it gl w b
