02 Civic SI BTL 18 Build!
Not a bad amp for 200 bucks. It made my old BL 15 bottom out pretty bad before I sold it, so you know its got some power.
02 Civic Si
Stock Alt
Kicker 0 gauge wire
Shuriken SK-BT80 Battery
JL Audio J2 320.4
Planet Audio BB 2400.1
Fi BTL 18 ufo motor
My 02 Si Build! http://www.stevemead...__fromsearch__1
Picked up my aero ports from parts express today and got one of the holes drawn up and the other cut, they look real good!
02 Civic Si
Stock Alt
Kicker 0 gauge wire
JL Audio J2 320.4
Fi BTL 18 ufo motor
I originally planned on having the ports staggered so they are on the other side of the box away from the sub, but the bottom one would hit my seat. Sooo instead Im just going to cut them side by side as you can see by the pictures. Think the one closes to the woofer will be okay that close? If im correct it shouldnt sound any different any place I put it right?
02 Civic Si
Stock Alt
Kicker 0 gauge wire
JL Audio J2 320.4
Fi BTL 18 ufo motor
I'd put the second port diagonally from the first one, furthest away from the sub(you already have it marked out :) ) vs. right next to it. I'm worried that you might get some loading issues if you put them side by side
Edit: Just noticed that it isn't an option. I would just put the port as far from the cone of the sub as you can. You may have to trim the rim(s) of the port to get it to fit how you want it.
I may just prop the box up a few inches. It only missed by a tad bit, but I really don't want to remove my seat. Think putting it diagonally would be worth the hassle?
02 Civic Si
Stock Alt
Kicker 0 gauge wire
JL Audio J2 320.4
Fi BTL 18 ufo motor
^^Do That^^
And for it being worth the hassle: Yes. If the port is right next to the sub, it **might** cause some loading issues with the box
^^Do That^^
Yeah good idea, it looks cooler diagonal anyways :P
02 Civic Si
Stock Alt
Kicker 0 gauge wire
JL Audio J2 320.4
Fi BTL 18 ufo motor
She's almost done! I have it in my car and playing, pretty damn low! :) sanding and bedliner come this weekend :)
IMAG1187.jpgIMAG1188.jpgIMAG1189.jpgIMAG1200.jpgIMAG1201.jpgIMAG1202.jpgIMAG1210.jpgIMAG1269.jpgIMAG1275.jpg
02 Civic Si
Stock Alt
Kicker 0 gauge wire
JL Audio J2 320.4
Fi BTL 18 ufo motor
