1 RF P5002- 150 + shipping
10/10 mechanically
8/10 cosmetically
1 rf P6002-only had for a few months 200+ shipping
10/10 mechanically
10/10 cosmetically
1 RF T1 12" Dual 2 ohm woofer- 200+shipping
1 month old perfect condition
f you have any questons post em up here and ill be glad to answer
your wish is my command
*Pic*
this was taken after installation in the amprack hence the saw dust..dont worry about that
specs:
Description Value
CEA-2006 Compliant
Number of Channels 2
Rated Power 150 W x 2 @ 4 Ohms RMS
300 W x 2 @ 2 Ohms RMS
600 W x 1 @ 4 Ohms bridged RMS
Total Power 600 Watts
Bridgeable Yes
Crossover Controls High-Pass (HP): 40-400Hz 12dB/octave Butterworth
Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
Tone Controls Bass: 0dB to +18dB @ 45Hz
Signal Input Low level: 1 RCA pair
Signal Output Low level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Punch Bass EQ (included with cable)
Visual Indicators Power On
Signal Level
Thermal Status
Speaker Protection
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/- 0.5 dB
Dimensions 2.4 x 11 x 16.4 (in)
6.1 x 27.9 x 41.6 (cm)
Shipping Weight 15.5 Lbs.
(7 Kg.)
on the birthsheet it said 720wrms brdged @ 2 ohm..
why you selling???
NoFearX18 said:
trainman0978 said:
This topic is now closed to further replies.
