Box design for 4 10's
36wide x 16tall x 20 deep.
also i am really starting to think it would be a lot easier just to do a standard rectangle box with 4 10s facing up and port back towards the trunk lid.
Car
1999 Dodge Stratus 2.5L V6
Deck
Kenwood DDX-512 Head Unit
Doors
(2) Diamond Audio DA6.6 6.5's
(2) Cerwin Vega 3" Horn Tweeters
(1) Alpine MRP-F240 for Doors & Tweets
Rear Deck(on factory wiring)
(2) JVC 6.5's
(2) Rockford Fosgate 6x9's
Subs firing forward
(2) Skar Audio VVX-12's
(1) MBQuart ONX1500.1D for Subs
Wiring
Cadence 4AWG for MBQuart Amp
Advance Auto 8 AWG for Alpine Amp
Cadence and Monster 4 AWG Wire to Kinetic HC1200
Batteries
Stock Replacement up front
Kinetic HC1200 in the back for the amps.
And yes "I drive a Dodge Stratus"
Here is my build log:
http://www.stevemead...__fromsearch__1
this is for a trunk?
don't do subs up port back.
you're better off doing the first design sealed. have all 4 10's facing in towards the cabin then you can seal it off from the trunk.
More box builds
I'm with captain stupid.
wont fit. the opening into the cabin is only 14tall x 32wide
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
You def have enough airspace (5.3 cuft net) for the ported but don'have enough space in the baffle for a port or ports, that's the problem.
Guess that you need to go for the sealed (2 cubic feet), or use two high power 12" ported would outperform the Bostons easily, something like 2 x Fi SSD 12" in a ported configuration.
well i got the boston g2 10's for 250 for all four. im not trying to sell anymore im sticking with these. so how could i do a normal box. all four facing up?
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
The best thing that you could do is take the design that was given to you with the four subs firing forward, just making the internal volume 2 cubic feet, if you want to do what you just said here's how:
DIMENSIONS AS SEEN FROM THE TOP!!
Enclosure Specifications:
Vgross = 2.073 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 23 in
External Width = 23 in
External Depth = 10 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 23 x 23
Left & Right Sides = 7 3/4 x 21 1/2
Top & Bottom = 23 x 7 3/4
well the design i like the most is this. i want it to be seoerated into two boxes because one big box like this wont fit in my trunk opening. I would want it seperated right down the middle so i will have one facing forward and one facing sideways in each box. is this possible and will it stay within y dimensons and the right amount of airspace.
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
kinda like this
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
