Guest Posted February 12, 2012 Report Share Posted February 12, 2012 when you get around to making your final box, use MDF or birch, not plain plywood like you did on the first page. Link to comment Share on other sites More sharing options...
DODGE-BASSHEAD25 Posted February 12, 2012 Author Report Share Posted February 12, 2012 when you get around to making your final box, use MDF or birch, not plain plywood like you did on the first page. Yeah everything will be 3/4" MDF Car 1999 Dodge Stratus 2.5L V6 Deck Kenwood DDX-512 Head Unit Doors (2) Diamond Audio DA6.6 6.5's (2) Cerwin Vega 3" Horn Tweeters (1) Alpine MRP-F240 for Doors & Tweets Rear Deck(on factory wiring) (2) JVC 6.5's (2) Rockford Fosgate 6x9's Subs firing forward (2) Skar Audio VVX-12's (1) MBQuart ONX1500.1D for Subs Wiring Cadence 4AWG for MBQuart Amp Advance Auto 8 AWG for Alpine Amp Cadence and Monster 4 AWG Wire to Kinetic HC1200 Batteries Stock Replacement up front Kinetic HC1200 in the back for the amps. And yes "I drive a Dodge Stratus" Here is my build log: http://www.stevemead...__fromsearch__1 Link to comment Share on other sites More sharing options...
Joe X Posted February 12, 2012 Report Share Posted February 12, 2012 Here are the suggested braces: Is not like they are stricty necessary but I would do them. Link to comment Share on other sites More sharing options...
DODGE-BASSHEAD25 Posted February 12, 2012 Author Report Share Posted February 12, 2012 Here are the suggested braces: Is not like they are stricty necessary but I would do them. What do you think about the rectangle box idea? Car 1999 Dodge Stratus 2.5L V6 Deck Kenwood DDX-512 Head Unit Doors (2) Diamond Audio DA6.6 6.5's (2) Cerwin Vega 3" Horn Tweeters (1) Alpine MRP-F240 for Doors & Tweets Rear Deck(on factory wiring) (2) JVC 6.5's (2) Rockford Fosgate 6x9's Subs firing forward (2) Skar Audio VVX-12's (1) MBQuart ONX1500.1D for Subs Wiring Cadence 4AWG for MBQuart Amp Advance Auto 8 AWG for Alpine Amp Cadence and Monster 4 AWG Wire to Kinetic HC1200 Batteries Stock Replacement up front Kinetic HC1200 in the back for the amps. And yes "I drive a Dodge Stratus" Here is my build log: http://www.stevemead...__fromsearch__1 Link to comment Share on other sites More sharing options...
Joe X Posted February 12, 2012 Report Share Posted February 12, 2012 The best thing that you could do is take the design that was given to you with the four subs firing forward, just making the internal volume 2 cubic feet, if you want to do what you just said here's how: DIMENSIONS AS SEEN FROM THE TOP!! Enclosure Specifications: Vgross = 2.073 ft^3 Subwoofer Mounting = Flush Mounted External Height = 23 in External Width = 23 in External Depth = 10 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 23 x 23 Left & Right Sides = 7 3/4 x 21 1/2 Top & Bottom = 23 x 7 3/4 I case you missed it I already gave you that design, it's no good for trunk type of vehicles. I would use 2 of them in a ported box to get just as loud or better yet 2 12" or a single 15" all are good options. The V design will work well but yes it will take some effort to build. Link to comment Share on other sites More sharing options...
DODGE-BASSHEAD25 Posted February 12, 2012 Author Report Share Posted February 12, 2012 The best thing that you could do is take the design that was given to you with the four subs firing forward, just making the internal volume 2 cubic feet, if you want to do what you just said here's how: DIMENSIONS AS SEEN FROM THE TOP!! Enclosure Specifications: Vgross = 2.073 ft^3 Subwoofer Mounting = Flush Mounted External Height = 23 in External Width = 23 in External Depth = 10 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 23 x 23 Left & Right Sides = 7 3/4 x 21 1/2 Top & Bottom = 23 x 7 3/4 I case you missed it I already gave you that design, it's no good for trunk type of vehicles. I would use 2 of them in a ported box to get just as loud or better yet 2 12" or a single 15" all are good options. The V design will work well but yes it will take some effort to build. So why doesn't it work good for trunks? Car 1999 Dodge Stratus 2.5L V6 Deck Kenwood DDX-512 Head Unit Doors (2) Diamond Audio DA6.6 6.5's (2) Cerwin Vega 3" Horn Tweeters (1) Alpine MRP-F240 for Doors & Tweets Rear Deck(on factory wiring) (2) JVC 6.5's (2) Rockford Fosgate 6x9's Subs firing forward (2) Skar Audio VVX-12's (1) MBQuart ONX1500.1D for Subs Wiring Cadence 4AWG for MBQuart Amp Advance Auto 8 AWG for Alpine Amp Cadence and Monster 4 AWG Wire to Kinetic HC1200 Batteries Stock Replacement up front Kinetic HC1200 in the back for the amps. And yes "I drive a Dodge Stratus" Here is my build log: http://www.stevemead...__fromsearch__1 Link to comment Share on other sites More sharing options...
Joe X Posted February 12, 2012 Report Share Posted February 12, 2012 It just keep flexing the trunk lid, the energy is translated into rattling and there is not much of a point on doing that but I guess you can always try... Link to comment Share on other sites More sharing options...
DODGE-BASSHEAD25 Posted February 12, 2012 Author Report Share Posted February 12, 2012 It just keep flexing the trunk lid, the energy is translated into rattling and there is not much of a point on doing that but I guess you can always try... Will it put out any SPL at all? I mean I just want to hit around a 120db on demand. Will it at least sound good? Car 1999 Dodge Stratus 2.5L V6 Deck Kenwood DDX-512 Head Unit Doors (2) Diamond Audio DA6.6 6.5's (2) Cerwin Vega 3" Horn Tweeters (1) Alpine MRP-F240 for Doors & Tweets Rear Deck(on factory wiring) (2) JVC 6.5's (2) Rockford Fosgate 6x9's Subs firing forward (2) Skar Audio VVX-12's (1) MBQuart ONX1500.1D for Subs Wiring Cadence 4AWG for MBQuart Amp Advance Auto 8 AWG for Alpine Amp Cadence and Monster 4 AWG Wire to Kinetic HC1200 Batteries Stock Replacement up front Kinetic HC1200 in the back for the amps. And yes "I drive a Dodge Stratus" Here is my build log: http://www.stevemead...__fromsearch__1 Link to comment Share on other sites More sharing options...
412 CVX Posted February 12, 2012 Report Share Posted February 12, 2012 just go with the above suggested design. the one with the V shape. don't do anything where the subs are upward facing, because that makes the trunk lid rattle and flex, rather than the sound being transferred into the cabin of the car. the only other option i forsee here is possibly a 4th order. something like this But on a litte bit smaller scale. i'd think a 4th order would be a little louder than sealed too. shoot me a PM if you would like me to design you something like this. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
Joe X Posted February 12, 2012 Report Share Posted February 12, 2012 It just keep flexing the trunk lid, the energy is translated into rattling and there is not much of a point on doing that but I guess you can always try... Will it put out any SPL at all? I mean I just want to hit around a 120db on demand. Will it at least sound good? No one will advise you to do that box, wil it sound good to you?? well who knows, if you put 2 of those subs on a ported box will sound AS LOUD as 4 in a sealed. That would sound to me as a good deal! Link to comment Share on other sites More sharing options...
