Box design for 4 10's
You could do that with the outer subs only. Don't know if sound would be affected that much but I would opt out that option myself.
im just thinking it would be a easier box to build. and im not too good with cutting and mounting to make rings and the different locations of the subs. why wuld you opt out of it? and when i mount them will i need to reverse the ploarity by reversing the speaker wires on the inverted subs?
Well I just prefer not to have one sub firing at the body of another one, most likely it's not a big deal but if it can be avoided I would certainly do, also you will need to have wiring exposed. The MDF rings ca be found on eBay in quantities if you just opt out doing the job yourself.
I mean, I am still all in for a 2 sub ported design, usually you cut 8-9 rectangular pieces if wood - no angles and you are done.
But it won't make the subs soundalike completely as crappy as possible. Still sound pretty good.
Car
1999 Dodge Stratus 2.5L V6
Deck
Kenwood DDX-512 Head Unit
Doors
(2) Diamond Audio DA6.6 6.5's
(2) Cerwin Vega 3" Horn Tweeters
(1) Alpine MRP-F240 for Doors & Tweets
Rear Deck(on factory wiring)
(2) JVC 6.5's
(2) Rockford Fosgate 6x9's
Subs firing forward
(2) Skar Audio VVX-12's
(1) MBQuart ONX1500.1D for Subs
Wiring
Cadence 4AWG for MBQuart Amp
Advance Auto 8 AWG for Alpine Amp
Cadence and Monster 4 AWG Wire to Kinetic HC1200
Batteries
Stock Replacement up front
Kinetic HC1200 in the back for the amps.
And yes "I drive a Dodge Stratus"
Here is my build log:
http://www.stevemead...__fromsearch__1
could i add rings to the first design to make the subs fit?
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
ok so i will just use te new design. another thing im wondering. tis is my first box. what do i use. i know wood glue and in the corners when its together but what do i use to build it. screws,nails, what?
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
so pretty much mock-up,pre-drill,glue, and then screw for each piece?
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
The quality of the cuts will have an important effect on the quality of the job. After assembly you must seal it completely as instructed in the document, must be air tight to work properly, use Titebond glue not some cheap generic one, MDF screws can save you from a crack are not expensive or hard to find, always drill pilot holes before screwing all this as general guidelines.
The baffle sheets must be particularily solid, and I would strongly recommend using the braces shown, if you want me to provide dimensions for those braces let me know.
Let me know before any cutting actually takes place to triple check all the calculations.
Well I changed my mind and I'm going with the slant box. The "V" is more complicated than I want to try on my first box. So can you tell me what the angles are on these cuts for the top board and the front and back pieces. And also let me know if all these dimensions are correct?
http://c714091.r91.cf2.rackcdn.com/b38f8c1b5dffa37e71016e845c5882378a3906104d.png
http://c714091.r91.cf2.rackcdn.com/b38f8c1b5de0adf41f67ba0ee8c62fb7210d76df46.png
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
  • Who's Online   2 Members, 0 Anonymous, 1473 Guests (See full list)
