Box design for 4 10's
65.1 and 24.9 respectively (the complement divided by two for the cuts), the problem with that design is that the internal volume is way above BA uses, around 3.1 cubic feet, most likely overexcursion will result at or below rated power.
So I guess there is no choice but to go balls to the wall and go for the "V" and learn from my mistakes. Could I get the dimension on those braces and also how much wide should the rings be. I know 3/4" thick obviously but ow wide.
Car
1999 Dodge Stratus 2.5L V6
Deck
Kenwood DDX-512 Head Unit
Doors
(2) Diamond Audio DA6.6 6.5's
(2) Cerwin Vega 3" Horn Tweeters
(1) Alpine MRP-F240 for Doors & Tweets
Rear Deck(on factory wiring)
(2) JVC 6.5's
(2) Rockford Fosgate 6x9's
Subs firing forward
(2) Skar Audio VVX-12's
(1) MBQuart ONX1500.1D for Subs
Wiring
Cadence 4AWG for MBQuart Amp
Advance Auto 8 AWG for Alpine Amp
Cadence and Monster 4 AWG Wire to Kinetic HC1200
Batteries
Stock Replacement up front
Kinetic HC1200 in the back for the amps.
And yes "I drive a Dodge Stratus"
Here is my build log:
http://www.stevemead...__fromsearch__1
Ok so I rechecked everything and couldn't find any issues, the rings should have an internal diameter same as the hole on the baffle and an external diameter same as the external diameter of the sub, the brace dimensions are as follows:
ok cool. so the rings will be the same as the outside diameter of the sub? not the mounting diameter?
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
9 1/4 inner (same as the cutout on the baffle) 10 1/2 outer.
Ok. Hopefully gonna start it this week. Will definitely be done by the end of next week. Hoping to have it in and bumpin by next Sunday
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
Just to check this is what I need right?
Top and bottom: 36 x 18 1/2"
Sides: 14 1/2 x 18 1/2
Back: 14 1/2 x 22 9/16
Two MDF rings for mounting the outer subs
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
Back: 34 1/2 x 14 1/2"
2 x Baffle: 14 1/2 x 22 9/16 50 deg cuts. ( to make sure you have enough material for rhe angled cuts make it 24)
2x Ring: 9 1/4 inner - 10 1/2 outer.
2x Brace: 10 x 4
2x Brace: 10 x 4
Ok. I had it written down different but must've messed up when typing. Lol. Again thanks for all your help Joe I will definitely post pics during the build and when it's done.
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
Ok, just work slowly and to detail, is not as hard as it looks. If you have any questions ask, there are a number of tutorials on box building watch a couple of them..luck.
Thanks for the luck. And the angles are 100 in the middle divided into two 50s and 40 on the sides right.
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
  • Who's Online   0 Members, 0 Anonymous, 1199 Guests (See full list)
