Box design for 4 10's
Thanks for the luck. And the angles are 100 in the middle divided into two 50s and 40 on the sides right.
Right but the cuts to the baffles are both 50 deg let me explain briefly:
90 - 40 = 50 deg , 100/2 = 50 deg
So both cuts are identical.
that confused me. the cuts that make the middle of the 'V' are 50 degrees each and the ends that mount to the side of the box are 40 degrees right? so i have will have two baffles that have one side with a 40 degree and one with a a 50 degree angle correct?
Car
1999 Dodge Stratus 2.5L V6
Deck
Kenwood DDX-512 Head Unit
Doors
(2) Diamond Audio DA6.6 6.5's
(2) Cerwin Vega 3" Horn Tweeters
(1) Alpine MRP-F240 for Doors & Tweets
Rear Deck(on factory wiring)
(2) JVC 6.5's
(2) Rockford Fosgate 6x9's
Subs firing forward
(2) Skar Audio VVX-12's
(1) MBQuart ONX1500.1D for Subs
Wiring
Cadence 4AWG for MBQuart Amp
Advance Auto 8 AWG for Alpine Amp
Cadence and Monster 4 AWG Wire to Kinetic HC1200
Batteries
Stock Replacement up front
Kinetic HC1200 in the back for the amps.
And yes "I drive a Dodge Stratus"
Here is my build log:
http://www.stevemead...__fromsearch__1
Each baffle goes towards the center in a 40 deg angle as I stated before BUT since they assemble to the sidewalls the cut is 90-40 = 50 deg, in the center the angle between the baffles is 100 deg so 50 + 50 = 100 deg, both cuts are parallel and both are 50 deg.
So both baffles will be cut to a 50 degree angle on each side!
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
Right, ask all the questions you need so everything goes smoothly, also the best way to determine the baffle that needs to be cut is cutting the bottom and drawing on it, back wall side walls and baffles, you can pick up from there the REAL dims of the baffles
ok gotcha
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
Picking up MDF tomorrow morning and hoping to get the sides and back mounted to the bottom. Will have pics tomorrow afternoon.
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
Well i got the MDF picked up in my dad's trailer. and yes ,he works for snapon as a manager. so i went and got a sheet of MDF and the guy at Home Depot got all my cuts out of one sheet. And i got some titebond wood glue. and i had some deck screws laying around so i used those. Today i got the back and sides done. glued and screwed and surprisingly no splits. not bad for my first box. i work tomorrow so friday i plan on getting the baffles mounted and the top put on. then saturday comes putting the box in and getting it wired up. so here is what i did today.
Here is the pics of the build.
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
  • Who's Online   0 Members, 0 Anonymous, 1199 Guests (See full list)
