I want to get a amp and install my 2 type rs and 2 type s but not sure how hard it will b to hook it all up. Am u gonna have to rerun all wires or could I just bypass old jbl amp that came in car to the new one.
Most of the time you have to locate the amp and disable it and run the wires from it to the new amp but use seperate 4 gauge or 0 gauge power and grounds for the new amp only thing you keep from the old amp is the speaker wires.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
i have a RF T1000.4 with 4 tweeters and 6 door speakers connected to it
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
Well i found it. Its under the glove box but haven't got to look at it yet. So I will need 4 or 0 gauge for a 400 w amp?
Okay perfect then just figure out which wires power which speakers and extend them to wherever you're putting the amp and technically you don't need 4 gauge but if the amp can accept 4 gauge power and ground no harm in doing it. The minimum I run is 4 and depending on the distance from the battery you will need to run 4 if it's going in your trunk.
2013 Dodge Charger
Build Log
Build Log
Build Log
My Selling Feedback
Well i was kinda thinking I could remove the old one and put the other one there or just under my passenger seat. And wont it b kinda hard tto run new power and ground thru firewall and across the engine?
