96 s10 cadence audio build
the system turned out good!
one suggestion to keep the material (fleece, or whatever you use) from wrinkling up on you and making more work. Pull it tighter in the beginning and use less resin on the initial coat until it locks up for you. I always get just enough on it to get it stiff. (uhhhh ya, i said stiff lol). Then after it sets up, put more on it inside and out. Then you can go buck-wild with the glass. If you put to much resin on the fleece in the beginning it will saturate and start to sag. I love the way the finished product turned out though, just a little extra work never hurt nobody!
good luck on system of the month bro!
thanks steve.... appreciate the positive criticism and always down to learn more tricks to speed up the process of glass work.
hopefully this month i can get more votes than i got last time.......i know the system isnt ground n pound but i still giving it a shot. cant wait til voting starts.
audio setup
HU: sony
Amps: cadence csa5000.1(running at 1 ohm 1200w x 1)
Subs: pair of cadence s2w8-s2
Doors: cadence zrs65k's component set
Box: customed glassed box tuned @ 35 hz with one 4" port....built by me
Underhood: powerbastards.com H/O 200 amp alt, big 3 upgrade(4 awg) and optima red top battery
Wiring: SQ audio 0 awg amp kit
Cadence Sponsored
build
http://www.stevemeadedesigns.com/board/topic/133648-96-s10-cadence-audio-build/page__hl__cadence
  • Who's Online   0 Members, 0 Anonymous, 1901 Guests (See full list)
