96 s10 cadence audio build
well recently decided to go on a limb and see if i could get any type of sponsorship for my truck and ended up with a small deal with cadence audio, so figured it was time to get out with the old and bring in the new slowly.
first off here is the truck.....
the old system.... 2 12" kicker L5 running off a directed audio 2400 mono amp
and the box was built by me(first attempt at glass work)
the doors did have sony 3-ways in them but upgraded them to a component set from Cadence audio..... have plans to move the crossover(tight fit but works for now)
now onto the new subs.... picked up a pair of the new cadence s2w8s 8" subwoofers and they will be powered by a cadence amp, the csa5000.1 mono amp running at 1200w x 1 @ 1 ohm
the box is a customed glassed box built by me. i will be around 2.1 cubes and be tuned @ 35 hz with one 4" port
here is the progress on the box so far
so far the box has 2 layers of resin only on the outside and the inside has 1 layer of resin only and 2 layers of resin with glass.... i plan on laying down at least 6 layers on the inside and then 1 layer on the outside where it is needed.
audio setup
HU: sony
Amps: cadence csa5000.1(running at 1 ohm 1200w x 1)
Subs: pair of cadence s2w8-s2
Doors: cadence zrs65k's component set
Box: customed glassed box tuned @ 35 hz with one 4" port....built by me
Underhood: powerbastards.com H/O 200 amp alt, big 3 upgrade(4 awg) and optima red top battery
Wiring: SQ audio 0 awg amp kit
Cadence Sponsored
build
http://www.stevemeadedesigns.com/board/topic/133648-96-s10-cadence-audio-build/page__hl__cadence
well inside now has a total of 1 layer resin and 6 layers of glass and resin... total of 7 layers and the outside has 2 layers of just resin.... now body work happens.
audio setup
HU: sony
Cadence Sponsored
build
Looks like a strong start!
1989 Dodge D150, 318 LA; Holley Fuel InjectionBuild Log:http://www.stevemeadedesigns.com/board/topic/72838-dc-dodge-d150-blowthrough-thread-updated-pics-fixed-2-level-4-15s-wlvl-5-coils/Truck Add-ons: 20" rims2/4 drop15% tintBucket seatsK&N air filterSmog Pump deleteStereoWORK IN PROGRESS2 DC Level 4 15s with Level 5 Coils1 Audiopipe AP15001D (Soon to be a Crescendo BC3500)JBL 650W amp (unsure of model)4 6x9 Rockford Prime 3 ways2 Soundstream TWS.4 Dome tweetersKnuKonceptz 1/0 Power Wire
*3 Kinetik 2400s and a Mechman 270A alt in the future*
looks like a good build, not a lot of people on here use cadence. It be cool to see what you do with them
thanks and thats what i figured from reading a bit on this forum. i am looking forward myself to see what these 8s can do. hopefully tomorrow i will have some updated pics of some body work done or at least a test fit picture since the box has some shape now.
audio setup
HU: sony
Cadence Sponsored
build
Nice start. The only thing I would do is add some fiberglass to the edges where the fleece and the wood meet on the inside. Just to add a little strength to the area. But overall looking nice. Now have fun sanding.
formerly known as Blue86f150
this sux camel dicks
thanks blue
audio setup
HU: sony
Cadence Sponsored
build
  • Who's Online   0 Members, 0 Anonymous, 1840 Guests (See full list)
