Jaloosk Posted February 9, 2012 Report Posted February 9, 2012 do you just need the username in there? Then use the environment variable %username% C:\Users\%username%\AppData\Local\Microsoft\Windows Virtual PC\Virtual Machines C:\Users\%username%\Virtual Machines "Cheap, good or fast. You can only pick two out of three." "Have money? Love story! No money? I'm sorry."
Guest Posted February 9, 2012 Report Posted February 9, 2012 i need to delete both folders and their contents for every user on each computer. users will be different for each computer ill try both ideas out when i get to work, ill let you guys know how it goes
Guest Posted February 9, 2012 Report Posted February 9, 2012 @echo off for /d %%d in ("%userprofile%\..\*.*") do rd "%%d\AppData\Local\Microsoft\Windows Virtual PC\Virtual Machines\" /s /q @echo off for /d %%d in ("%userprofile%\..\*.*") do rd "%%d\virtual machines\" /s /q and yes i tried \virtual machines\*.* but it doesnt work :/ this is the best i could come up with.. ive been looking how to clear out the files and not the folder for two hours.. hope i helped also please be aware that this is a HOT batch file.. meaning that it will destroy all data on every single user profile (except hidden ones) in the specified folders. this is a working batch file for your needs, i just wish it didnt delete the final "virtual machines" folder and instead deleted all the files inside. to get this to work (in case you dont know how) make a new text document and copy and paste the above into it, save it and fix the extension to .bat. or if you know a faster way to make a .bat file, open the .bat file and edit it and paste the above into it. this batch file has no pause command so all you will see is a flash on the screen then its done it worked perfect man! i needed the folder deleted as well so it all worked out great. boss man is very happy
Sheena Posted February 9, 2012 Report Posted February 9, 2012 np kranny, glad i could be of service to you sir :] 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
