Batch File and Wildcards...headache
im trying to create a batch file that needs to delete two folders in two different directories for ALL the users. user names will vary since this needs to be ran on like a hundred different computers.
i tried googling this to no avail. i just need to use a wild card to delete the files in every user but i cant seem to find one that works.
for reference, im trying to delete from:
C:\Users\*need user wild card here*\AppData\Local\Microsoft\Windows Virtual PC\Virtual Machines
and
C:\Users\*same wildcard*\Virtual Machines
Hehehe I'll look later on its gonna get lots of errors what os
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
windows 7
You know since its in those directories you may not be able to get them. Can you manually deleyenthem? Uac turned off on all boxes?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
yeah uac is turned off. we can delete them manually no problem but it would be a pain in the ass to do that hundreds of times for upwards of like 20 users on a computer, you know?
try to talk to sensai. Hes alot better at scripting than I am.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i can make one that deletes the last folder across all users.. so both the "\Virtual Machines" folders will be deleted.. im trying to figure out how to just delete the content inside of it, but no luck
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
@echo off
for /d %%d in ("%userprofile%\..\*.*") do rd "%%d\AppData\Local\Microsoft\Windows Virtual PC\Virtual Machines\" /s /q
@echo off
for /d %%d in ("%userprofile%\..\*.*") do rd "%%d\virtual machines\" /s /q
and yes i tried \virtual machines\*.*
but it doesnt work :/ this is the best i could come up with.. ive been looking how to clear out the files and not the folder for two hours.. hope i helped
also please be aware that this is a HOT batch file.. meaning that it will destroy all data on every single user profile (except hidden ones) in the specified folders.
this is a working batch file for your needs, i just wish it didnt delete the final "virtual machines" folder and instead deleted all the files inside.
to get this to work (in case you dont know how) make a new text document and copy and paste the above into it, save it and fix the extension to .bat.
or if you know a faster way to make a .bat file, open the .bat file and edit it and paste the above into it.
this batch file has no pause command so all you will see is a flash on the screen then its done
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
Create yourself a temporary environment variable in your batch file by including the following line at the start of the batch:
set variable_1=[whatever_you_want]
Then to recall, just use %variable_1%
"Cheap, good or fast. You can only pick two out of three."
"Have money? Love story! No money? I'm sorry."
