battlewalrus Posted February 11, 2012 Author Report Share Posted February 11, 2012 If you dont have a ground it will use the rca shield as a ground. Bad shit Does it mess the amp up or only the head unit? Quote 2005 Honda CR-V AQ HDC315-A Hifonics BRZ1700.1D .5 Ohm 4.4 ft^3 box Kenwood Deck Big 3 XS Power D5100R Starter, D975 Rear Link to comment Share on other sites More sharing options...
Ray Posted February 11, 2012 Report Share Posted February 11, 2012 Typically just the deck. But only pioneers. Just fix your gronud Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
battlewalrus Posted February 11, 2012 Author Report Share Posted February 11, 2012 Typically just the deck. But only pioneers. Just fix your gronud Alright 14v going from the power to ground doesn't necessarily mean a good ground right Quote 2005 Honda CR-V AQ HDC315-A Hifonics BRZ1700.1D .5 Ohm 4.4 ft^3 box Kenwood Deck Big 3 XS Power D5100R Starter, D975 Rear Link to comment Share on other sites More sharing options...
Ray Posted February 11, 2012 Report Share Posted February 11, 2012 What ground? At the amp? And no, it doesnt. Need to do a ohm check between amp ground terminal and sheet metal of the car. That should read 0.00 ohms. Not like 80 ohms. Lol Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
timwebb Posted February 11, 2012 Report Share Posted February 11, 2012 where is your ground? Quote Link to comment Share on other sites More sharing options...
battlewalrus Posted February 11, 2012 Author Report Share Posted February 11, 2012 where is your ground? Bolted under a grommet that is used to hold stuff in the cargo area Quote 2005 Honda CR-V AQ HDC315-A Hifonics BRZ1700.1D .5 Ohm 4.4 ft^3 box Kenwood Deck Big 3 XS Power D5100R Starter, D975 Rear Link to comment Share on other sites More sharing options...
timwebb Posted February 12, 2012 Report Share Posted February 12, 2012 u have a multi meter? Quote Link to comment Share on other sites More sharing options...
battlewalrus Posted February 12, 2012 Author Report Share Posted February 12, 2012 u have a multi meter? yeah Quote 2005 Honda CR-V AQ HDC315-A Hifonics BRZ1700.1D .5 Ohm 4.4 ft^3 box Kenwood Deck Big 3 XS Power D5100R Starter, D975 Rear Link to comment Share on other sites More sharing options...
Freshman6969 Posted February 12, 2012 Report Share Posted February 12, 2012 (edited) u have a multi meter? yeah put either of the probes on your ground, then put the other to bare metal(no paint), set your DMM to ohms (20 or so) and see what it reads, anything more then .04 is no good? idr, >>>>that .04 might be for parasitic drain and on millivolts <<<<<dis regaurd that OP lol talking to my self Edited February 12, 2012 by Freshman6969 Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
battlewalrus Posted February 13, 2012 Author Report Share Posted February 13, 2012 Yeah I pulled everything and re sanded the ground and then it started working thanks guys Quote 2005 Honda CR-V AQ HDC315-A Hifonics BRZ1700.1D .5 Ohm 4.4 ft^3 box Kenwood Deck Big 3 XS Power D5100R Starter, D975 Rear Link to comment Share on other sites More sharing options...
