I hooked up my new amp to see if it worked yesterday and it wouldn't turn on, so I metered the power wire and it was sitting at 14.4 volts to the ground and then I metered the remote wire and that was at 13.9 volts so I don't know why the amp isn't coming on.
The only thing I didn't check is the RCAs and I don't know how to check them.
It's a Hifonics BRZ1700.1D brand new
It turned on when I unplugged the left RCA for a second and then turned back off
2005 Honda CR-V
AQ HDC315-A
Hifonics BRZ1700.1D .5 Ohm
4.4 ft^3 box
Kenwood Deck
Big 3
XS Power D5100R Starter, D975 Rear
Does the power light come on. If not you have a bad amp. Only have power connected no speakers and rca and see if it powers on. You may have a short in your speaker wires and making it protect right away.
91' CRX Si
HU - Alpine cda-7995
All stock interior
Amp - Crescendo bc3500
Subs - 4 sa 10 d1 spl's
Batt - 3 x 100 ah
149.5 Street beat
Integra Build Log
try jumping the remote and b+
this wont do anything since he's getting 14v on both already.
is your amp ground in a good location/prepped well? where is it bolted to? if everything on the power connection side of the amp is good then the amp may be messed up :\
Edited by Kranny
I think it might be a ground problem because it turned on when I was moving everything around and the ground may have shifted and got a good connection to the chassis
I'm not building for a while anyway but it'd be nice to get everything sorted out before lol
2005 Honda CR-V
AQ HDC315-A
4.4 ft^3 box
Kenwood Deck
Big 3
Sounds like it was grounding thru the rcas.
Hope that wasnt a pioneer deck hooked to it.
It's a kenwood, and what do you mean grounding through the RCAs? Never heard of that before, please elaborate (obviously I know what it would be, but why)
Edited by battlewalrus
2005 Honda CR-V
AQ HDC315-A
4.4 ft^3 box
Kenwood Deck
Big 3
If you dont have a ground it will use the rca shield as a ground.
Bad shit
  • Who's Online   0 Members, 0 Anonymous, 1113 Guests (See full list)
