Amp won't turn on
battlewalrus
Typically just the deck.
But only pioneers.
Just fix your gronud
What ground?
At the amp?
And no, it doesnt.
Need to do a ohm check between amp ground terminal and sheet metal of the car.
That should read 0.00 ohms. Not like 80 ohms. Lol
u have a multi meter?
yeah
put either of the probes on your ground, then put the other to bare metal(no paint), set your DMM to ohms (20 or so) and see what it reads, anything more then .04 is no good? idr, >>>>that .04 might be for parasitic drain and on millivolts <<<<<dis regaurd that OP lol talking to my self
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
  • Who's Online   0 Members, 0 Anonymous, 1853 Guests (See full list)
