there will be no ability to use the home button in this install. Theres nearly nothing that gestures cant do in place of it, so thats my solution.
Go to accessibility then asistive touch and you can do it. My ipod home button is broken so thats how I go home on mine
not impressed!!!!! .......................... Im so lien omg this is clean clean clean love it!!!! i wish i could do work like this but how did u get the metal look to it?
My build
http://www.stevemead...20#entry2018495
Car: 2003 Cadillac DTS
(1) Hifonics Brutus BRZ2400.1
(1)Hifonics Zrx600.4
(1) 1000 watt crunch amp
(1)200 watt boss amp
(2) Pyramid TW46
(4) Infinity Kappa 60.9cs
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
umm every thing one thing i loved was the control nobs how did u get that clean look after cuting it?
My build
(2) Pyramid TW46
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
wow it came out clean clean clean!
My build
(2) Pyramid TW46
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
Ok so its been a minute since I have updated any build pix so Im gonna catch you guys up...
The Aluminum channel that the ipad slides into.
IMG_1815 by rogueauto, on Flickr
The 5mm thick backplate that connects the ipad bezel to the slides for motorization. It was machined down 1.5mm to make the channel aluminum sit flush in there and the front has been rounded over to make a nice transition for the ipad going in the slot. My Neighbor has been extremely helpful by getting the aluminum from scrap bin (and many other random parts) for me and having it cut down. I reworked it a tad and this is what I came out with.
IMG_1826 by rogueauto, on Flickr
IMG_1830 by rogueauto, on Flickr
IMG_1840 by rogueauto, on Flickr
IMG_1832 by rogueauto, on Flickr
IMG_1838 by rogueauto, on Flickr
Did some more work on the backplate and covered it with the same vinyl from earlier in the build so it matches everything. Its what you see when theres no ipad docked up. The backplate is attached to the large angle iron pieces i have mated together and bent at 11 degrees to accomodate the difference of the ipad and the angle the slides need to be at to function. Also plainted the slide mechanism (this is basically an extremely moddified keyboard slideout tray also provided by my neighbor).
IMG_1856 by rogueauto, on Flickr
IMG_1860 by rogueauto, on Flickr
Then I decided the channel would look better black even though it shouldnt be seen. It will be helpfull if the felt that will cover the channel shows any at its edge so just in case....
IMG_1864 by rogueauto, on Flickr
IMG_1861 by rogueauto, on Flickr
  • Who's Online   1 Member, 0 Anonymous, 1608 Guests (See full list)
