HELP
The gain is full (cause I'm not getting loud sound!) & ahh. I see. & I believe so it's either that or 180. What is phase anyways?
if you were to flip the subs so the magnet was faceing out, and the cone facing in, then you would put it on 180, other wise its at 0, checking your wiring and make sure the phase is at 0, the wiring is the only thing i could see to keep it from being loud at this point
and turn that gain down to 6 or 7
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Gain is like sensitivity I think. Sound right?
What could be my issue here anyways?
At first, one sub wouldn't play, I opened the box, and I had forgotten to plug it in. Then, it still wouldn't play, and I had forgotten to plug in the - terminal. FAIL. Could I have damaged the amp?
so no subs will play off the amp now?
and no the gain is pretty much the "limiter" to let power flow though the amp....thats in simple terms
try that
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Shell of box / baffle built by me
Port / sealing the box by John Hone
Fuck midrange
Alpine-9886
http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/
price has no influence on how something sounds
I told him to move the fucking port.
they see me hoppin they stoppin they can't believe im so white and dirty
It looks like you got so drunk, that someone came up and stole your leg.
recheck your wiring once, twice, and 3 times over, ive done it, and so has everyone else, its always something simple, that you dont notice, unless you sit there and stare at it
What area do you live in? Someone may be kind enough to give you hand in the daylight tomorrow or something.
this is true, im stumped if its not your wiring, or your amp settings
  • Who's Online   0 Members, 0 Anonymous, 1047 Guests (See full list)
