Your amp clipiing leaves if you set your gain´s with a DD 1 or oscope.
For the dimming, please tell us what amps did you use, how many and what batt´s did you have, and how many amps your alt run to the system.
Maby a batt and Big 3 help´s enough.
"in the abundance of water, the fool is thirsty" Bob Marley
we will need to know some more info, such as the amps, type of batteries, type of wire, and vehicle. What ohm load your running the amps.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
lol thick red wire, look on the wire itself, and read what gauge it is.
Kenwood H/U
1/0 wire,
Do the Big 3http://www.stevemeadedesigns.com/board/topic/13280-how-to-do-the-big-3-tutorial/ first and use 1/0 gauge , that´s the cheapest upgrade.
If it still dimm, biggest baddest batt you can fit under the hood, have a look in the want to sale section, Ram have a vew threads with used AGM batt´s
in diffrent sizes and nicepriced. That must be enough for your need´s.
  • Who's Online   1 Member, 0 Anonymous, 951 Guests (See full list)
