Angles enclosure & sealing off from trunk with 15"s ?
I was thinking about buying some 1000-1500rms 15"s (2) and attempting to seal them off from the trunk. The enclosure would have to a significant angle ( prolly between 45-65) because it has to be no taller than 13.5
Would having this much of an angle and then sealing it forward be a waste? I figure if it would work I would get more air movement and probably a little louder than the 3 10"s are.
I also was considering trading the aqs for something a little less power hungy, and getting 6 10" and sealing it forward ( 2 rows of 3 each at 45* so it would be similar to a clam i guess?) Would that idea work? It works in theory but idk.
Thanks for helping.
Build In Progress for Slamology 2013
3 m1xl 18s walled in a gti
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
Just go with two nice 12's and save room for a good size port. If you use aero ports, you may get away with using three 12's..
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
agree with kranny. fitting 6 10's in a sedan is unrealistic.
what are the max dimensions of your trunk? HxWxD?
More box builds
I'm with captain stupid.
So the 45 angle wouldn't work for the 10s? What about the 15" idea? Im just trying to get as much cone area as possible....cant blame someone for dreaming big lol
if box slides in 13.5h 39.5w 26d
if part of it were built in the car I could have 16.5h
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
unless you use a sawzall, you wont fit anything but 12's. if you want to fire forward
If you're willing to go through that much, build a 4th order for a couple 12's and fire it into the cabin. :)
Sub Amp: AB 450.1
XS D3100
Come on 150!
  • Who's Online   0 Members, 0 Anonymous, 1400 Guests (See full list)
