Best way to face box in trunk
seriousgary
But how to do it, this is my basic view of it(anyone correct me if I'm wrong) but you make you box first, then you make a baffle the shape of your trunk, and you put it over the box, and make sure the design doesn't have the woofers touch the seat, then you get the expanding foam spray(what Steve Meade refers as the "great stuff:) for extra sealing off the box. It's also a good idea to apply sound deadening mats on the rear deck to reduce rattle.
Done properly, you get this
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
If it's sealed off good the trunk won't rattle really.
91' CRX Si
HU - Alpine cda-7995
All stock interior
Amp - Crescendo bc3500
Subs - 4 sa 10 d1 spl's
Batt - 3 x 100 ah
149.5 Street beat
Integra Build Log
Yeah, you rarely will get rattle when facing forward. My friend with the 2 JL W3's, has them on an HD 750/1 in a sealed box, and rattle only occurs when his headunit is at least 33/35(loud as fuck lol), and the trunk and spolier barely rattles a bit and no body flex. Me, with just a cvr12 on a regular ported box on an MB Quart 600 watt mono amp, I suffer trunk rattle like crazy, and body flex, the rattle was so bad, it knocked off the spring inside the locking mechanism, so I couldn't lock my trunk, and had to go to my friends to fix it, so to reduce rattle, face it forward.
2003 Kia Sorento
Team Subsonic Lows
To do it yourself, shouldn't cost you that much extra, just extra mdf, expanding foam, and sub box carpet if you wanna make it look clean. To have a pro do it, well depends on the shop, you have to ask around, but it usually costs alot more, especially when they do it with fiberglass.
2003 Kia Sorento
Team Subsonic Lows
Yeah, seal off the baffle with the foam, then when everything is all set, cover it with box carpet to make it look good.
2003 Kia Sorento
Team Subsonic Lows
Good luck to you on your build, and ask around when you need help.
2003 Kia Sorento
Team Subsonic Lows
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
