if nothing is obviously burned then you need to check the RCA connectors to make sure the solder joints are not cracked.
I don't think anything is cracked as i didn't see any dodgy solder joints and i think i wouldn't have measured 1.3v on them if they werent attatched to anything.
did you follow them on the board a ways? If you get 1.3v on their backside that only means there's power coming into them, not necessarily getting to the PCB.
Hammerdown... 1%
I didn't't have any RCA's from anything plugged in though, so it was getting 1.3v from somewhere inside the amplifier.
  • Who's Online   0 Members, 0 Anonymous, 2726 Guests (See full list)
