Bought a used amplifier as untested in the hopes that maybe it worked. Plugged power, rem and earth in, power light came on and i was about to start having a party in my head, then when i connected the rca and cables to my sub it wouldn't play anything, absolutely gutted!
I was really looking forward to hearing this amp with my subs, atm i have 400w @ 2ohm to two subs. This amp runs 750w @ 2 ohm. I know its nothing compared to you guys but car audio is alot more expensive over here in the uk.
So i want to see if i can fix it, but i can't afford to send it away, nor do i know anywhere in the uk that fixes them.
I took it apart to see if maybe i could work out whats wrong with it, the only obvious thing i could find was a dark mark on the board.
This is what it looks like
From a bit further away.
On the otherside it was directly under one of those donut looking things, i was reading a tutorial about fixing amplifier last night and i think its the power supply transformer?
Does anyone know if this could be an easy fix? Im also going to check all the 3 pronged resistor things later to see if any of them have a broken circuit.
I apologise if any of the terms i've used are incorrect but im not an expert in resistors, capacitors and all the rest of that, i can only guess what i think they are from the brief tutorial i read.
Edit: Its a Vibe VP4 amplifier just in case anyone needs to know that.
Edited by Migz
If you can take better pics of the fets which are on the outside of the board and maybe some of the board in the middle to see if we can if see anything is smoked and or burnt.
Edited by Skullz
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Wil do when I get home. Will take it with a better camera as well.
3 pronged resistor????? Do you mean the transistors?
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
thats the inductor. the always run hot. it looks singled layers so im sure its good. u have a better description of what the amp does when first powered up?
Powers up fine, power light comes on, when i had it plugged in my girlfriends car the subwoofers just had no output at all. Tried different set of RCA's, same problem.
Got home and wired it to a spare computer PSU i have and plugged it into a 6x9, started making a sort of static noise, like the noise you get when you're not on a radio channel. Although i didn't hear that noise when it was in the car, couldve been because i wasn't close enough to the subs or could be interference from the PSU.
I twiddled with everything on the amp (gain, lpf, subsonic, phase) to see if it would affect the volume of the static noise but it didn't. It also made the noise when there was no rca's plugged in.
Yeah sorry, don't actually know the proper names of any of them, i just read a tutorial that went over the basics of what they are but couldn't remember exactly what it was.
Also going to get photos up sometime in the next hour, just need to upload some videos to youtube.
So im checking the outer bit of where the RCA plugs into the amplifier on the inside? I'll do it tomorow as it's 4:30am here so i need to go to bed. But will post back here with the results tomorow.
Also i've uploaded more pictures. They can be found here. Hopefully those are good enough.
Thanks.
I googled how to check rca shield, and it said that to do that i needed to put my negative probe on the amplifier ground, and my positive on the outer bit of the female RCA in on the amplifier.
I used that method and checked the outer metal of the female RCA area on the amplifier and i checked the center bit of the female RCA area on the amplifier. I did this on both the input and output.
All of them measured 1.3v (give or take 0.1)
I also tried measuring with my negative probe on the outer metal and my positive probe on the inside center bit, there was no voltage like that. I just tried that incase that mightve been a different way to do it.
if nothing is obviously burned then you need to check the RCA connectors to make sure the solder joints are not cracked.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 2852 Guests (See full list)
