4th order or 6th order?
sodfamily
Okay i started a new built and have my shell built and i have just under 24 cubes to work with. I have 6 sa 15's and 4 saz1500 that i am working with. Electrcial is good.
Here are the 3 4th order setups, plan on inverting all subs so that the backs are in the center chamber.
1st: 5.02 per sealed side with a common chamber of 10.8. this is with our sub and any port displacemnt in the common.
2nd: 5.56 per sealed side with a common chamber of 9.84 this is with our sub and any port displacemnt in the common.
3rd: 6.11 per sealed side with a common chamber of 8.92 this is with our sub and any port displacemnt in the common.
But i am very interested in maybe doing a series tuned 6th order with just 4 of the 15's. Can anyone give me some ideas on what kind of space i would be needing for this and tuning on the rear chamber and tuning on the common chamber. Any rule of thumb to follow with 6th orders? Tried and true methods? Basically anything..
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
whats with all the different chamber sizes?
Hammerdown... 1%
It is just a couple of options, I was just working with some numbers and came up with those ratio's.
  • Who's Online   0 Members, 0 Anonymous, 770 Guests (See full list)
