Power inverter power cable size?
i had 8ga. on my power supply, and i want a switch up front to turn it off instead of going under the seat to flip the switch. i opened it up to see if i could bypass the switch, there is a positive lead going from the screw terminal for the positive then into the board for the fuse then back out to the switch, the cable is 10 or 12 ga. its not that baig, so would mit hurt any if i ran 10 ga. to a toggle switch up front from it then back to it for on/off?
02 Dodge Durango
1 Fi SP4 18" .v2
Sundown SCV3k @.5 Ohms
XS D3100 up front
Northstar SMS AGM 400 in the back
All XS Power 0ga OFC
240a Apex h/o alternator
Pioneer AVH-X2500BT HU
Dual 0ga runs from the alt to battery
Dual 0ga runs from battery to amp
i think youd have to use some sort of heavy duty relay
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
why??
02 Dodge Durango
1 Fi SP4 18" .v2
XS D3100 up front
02 Dodge Durango
1 Fi SP4 18" .v2
XS D3100 up front
  • Who's Online   1 Member, 0 Anonymous, 471 Guests (See full list)
