What is the benefits of proper Ohms..Also need help with proper connections and settings
He's telling you to run the amp in stereo mode, 2 ohms per channel, like I stated earlier, but you told us one of the negatives isnt working so you cant get stereo output.
Overcurrent would be due to clipping probably, which can happen below tuning if you're just on the edge of between maximum output and clipped output and playing below tuning causes your impedence rise to be lost (all enclosures cause ipedence rise, some more than others).
Hammerdown... 1%
Thanks STEvil I appreciate your help.I think he was saying to wire it to 4 ohms like you started to say(I think it was you) cause he was talking about wiring it up then back down..The way I currently have them wired is positive to opposite terminals negative. So Series coils/Parallel Subs which is 4ohms and I think you said the amp will see it at 2ohms???
R.I.P...99'Dodge Grand Caravan
03 Lancer Oz
Big 3
HU-JVC KD-530
RCA's-rockerfosgate
41/2 inch Infinity mids
Subs-(12's)2 Orion xtr124
Amp-Coustic600se
battery-2 x stock, 1x Shuriken SK-BT20
Box-L-ported 3.562cubes@35Hz
miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive)
I dont have flex yet but damn I sound good,(coming soon....flex)
Check out my HHR install
Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/
Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
yup
Hammerdown... 1%
