STEvil Posted March 5, 2012 Report Posted March 5, 2012 He's telling you to run the amp in stereo mode, 2 ohms per channel, like I stated earlier, but you told us one of the negatives isnt working so you cant get stereo output. Overcurrent would be due to clipping probably, which can happen below tuning if you're just on the edge of between maximum output and clipped output and playing below tuning causes your impedence rise to be lost (all enclosures cause ipedence rise, some more than others). Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
MrFree Posted March 7, 2012 Author Report Posted March 7, 2012 Thanks STEvil I appreciate your help.I think he was saying to wire it to 4 ohms like you started to say(I think it was you) cause he was talking about wiring it up then back down..The way I currently have them wired is positive to opposite terminals negative. So Series coils/Parallel Subs which is 4ohms and I think you said the amp will see it at 2ohms??? Quote R.I.P...99'Dodge Grand Caravan 03 Lancer Oz Big 3 HU-JVC KD-530 RCA's-rockerfosgate 41/2 inch Infinity mids Subs-(12's)2 Orion xtr124 Amp-Coustic600se battery-2 x stock, 1x Shuriken SK-BT20 Box-L-ported 3.562cubes@35Hz miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive) I dont have flex yet but damn I sound good,(coming soon....flex) Check out my HHR install Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/ Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
STEvil Posted March 8, 2012 Report Posted March 8, 2012 yup Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
