So there is something I can do if they decide to pull a trick on me?
It's not really vibrations as much as air flow causing my amp to move. Like low notes push a lot of air and make the amp flex a bit even though it's secured down and has foam under it..
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
If you secured your amp down tight enough it shouldn't move.. at all. With your box being mounted as well nothing should move. I am suuuure there is something you can do, but that's something someone else can tell you, not all that wise on the legal stuff.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
The foam may help a little, but what I have done before is take rubber tubing and place it underneath the mount and about the screw head. Almost makes the amp "float" so to speak. As long as you use a thinner diameter screw and minor loose rubber tube it'll work. That way the screw isn't even touching the amp, the mounting holes are pressured between the two rubber grommets.
Personally I never put my amp close to my box, just puts more wear on it. But if you're tight on space try the method I just talked about.
The MDF walls are flexing, not the box moving..
Ahh..
Your box is vibrating?
Not like, flexing.. But it vibrates enough to where I can feel it. Unfortunately I didn't do any top to bottom bracing.
Hopefully the amp is a cheap fix. Something probably just got unsoldiered, right?
This is why i didn't think he ment flexing :P
  • Who's Online   0 Members, 0 Anonymous, 720 Guests (See full list)
